The VST parameter in the VST plugin in the DAW does not change when you change the program of the Sub 37 from either the Synth HW or by sending a program change message. Only if you change program using the plugin it changes in the the DAW
Thanks, will check it out !
Still does not work on RC3
Thanks,
It’s reported to next version (1.0.1)
