posting this here so everyone can benefit (pm from noSpoonMusic):
"Ive been following your rack case build. Well done. I had been toying around with different ways of doing this for a while and you took a great approach. How heavy is it? Also, can you tell me which connections you added resistors to? And what kind of resistor? I’ve gone through and tested all my foogers.
When I connect the Osc out to Osc in on the Ring Mod, the sound gets a little brighter than without patching. Any cure there?
The MidiMurf gives me slightly offset sounds when I patch into the rate, mix, envelope, and lfo/sweep. Im assuming these all need some kind of resistor. The amount of offset is slightly different on each, would using different resistors help this problem?
I also get a change in value when I patch the env amount on the Freq Box and the sweep in on the Phaser.
How did you address these issues. . .if you even had them at all.
Thanks"
so first off thank you. it was a lot of work.
the case is pretty heavy. i wish i would have sprung for the flyweight (expensive but super light material used instead of plywood). seriously, it’s totally worth it. a&s case company in north hollywood has all of these dimensions on file so they could easily make you one. mine was $450, but it would be a good deal more for the flyweight.
so yeah, a few things need to be normalled, ring mod carrier out to carrier in is one of them.
almost all of the murf and delay inputs (delay loop out to loop in just needs to be normalled) needed resistors. i can’t remember which inputs or the values of the resistors. honestly, i was just touching them to the contacts until i got it right. the murf knobs are different when it’s patched to the patchbay or when an expression pedal is used. it assumes that 12 o’clock is zero. it’s strange, but not really a bad thing. latigid has a thread that explains a lot of this stuff in greater detail. a lot of that info has been included in my thread.
a voodoo lab pedal power 2 plus will take care of everything. all pedals need the white barrel positive center cables, the freqbox needs a current doubler (y-cable adapter) and the murf and delay need to be plugged into the higher current outputs (5 and 6). the slim phatty will take the standard 120v outlet. it’s pretty much perfect. one power plug to the wall and you’re done! you’ll need some l brackets to mount the box to the back of the moogerfooger rackmount kit.
making 52 trs cables is not fun. you’ll need about 150’ of mogami w2549 balanced mic cable, 52 stright jacks, 48 right angle jacks, and a cable tester. also, netflix and snacks.
slim phatty next week, then i’m totally ready for synth sleepovers.
