Hey! what is used to connect the “sides” of the foogers to each other when the wooded sides are removed? I see screws… they have to be screwed into something…
{The reason I am asking is I need 1/4" of space min more then I have on my pedal board [20"X40"] to get all my foogers and MP201 to fit in a usable layout… so I am going to make a platform/shelf the holds 5 + my CP 251 to raise them about 2" up to put powering and cabling under them anyway so I am thinking about just making this like a doublewide rackmount thingy.}
If you look at the way that the CP-251/VX-351 rack mount works, it actually uses a center block of wood that screws into each of the adjacent devices. If you are crafty with a table router you can likely fashion one but there really is not much benefit.
The drilled holes in the MF rack mount kit allows for a combination of 2 x VX/CP size devices and one Fooger, or 3 x Fooger (if I get that right). I have my center Fooger strapped in with velcro, that way I can switch up depending on what I want on the rack vs. the floor. The rack mount kit comes with the same fancy black screws and nuts (because the type which goes into the wood are wood screws). From the front it looks seamless; nice and clean.
This is rack, that I’m after… so, does anyone know if I can instal 3 Moogers and 2 CP-251 on the top (with rack mount adapters) and one patchbay. In lower spaces I need to mount my Fireface and DP/4.
I also wonder if Moogerfooger rack mount come with wood panels to place them between the foogers. If not, than I have to make them by myself. Without wood between it seems that middle fooger is in danger.
I need measurements for the rack mount.
There is a lack of info about this rack mount kits. So any info is very welcome!
to install 3 foogers in a rackmount all you have to do is take away the wooden sides of the middle fooger. I dont know if they supply screws and washers for the middle one’s holes when the side’s are of. For the cp rackmount that one come’s with extra wooden block to join them together. Pretty cool, when i got out of space in my rack you can make nice
dubble tabltop cp untis with the’s block’s
