Quick MIDI USB question.
So I got some stuff for my comp to help expand the sounds of the Moog I have..well, I’m a horrible new guy when it comes to this, so I would need some help.
I’m running everything on a Toshiba laptop, so using USB is basically my only option. Is there some way I can use the USB as both an input and output? I mean, plugging the USB into my laptop, then using the filter/VSTi setting to have the sound be available on the moog?
It’s not possible to get audio over USB with the Phatty…only Midi over USB
So you have to connect the Phatty with your soundcard using standard audio cables.
