Question about Voyager LFO Speed.
When I had my LP, out of the box the LFO modulation rate went up to an ULTRA fast speed. I have a Voyager 3.2 and the rate only goes about half as fast. Is there something in the edit menu I need to adjust to get it to this faster rate?
Thanks in advance.
Seriously, no one can help me with this!!??
Use Osc. 3 to achieve a faster rate.
Was perhaps the On/Mod2 modulating the LFO speed to be higher than normal?
Spec-wise, the LP and Voyager LFO have the same range: 0.2 to 50Hz. There’s nothng in the Voyager’s Edit menu that changes/adjusts the rate.
If your Voyager LFO doesn’t cover the specified range, it needs to be adjusted. Contact Amos at Moog.
Analoghaze’ suggestion to use Oscillator 3 for really fast modulations is correct. An advantage to using Osc 3 this way is that the waveform can be adjusted for highly customizable modulations. Another advantage is that Osc 3 can track the keyboard - something the LFO can’t do.
