Question about Ringmod
Ok, so i loaned out my ring mod to a guy for a couple of months. I get it back, and I am not sure if the thing sounds different, or i just wasn’t paying close attention to it. Question: does the square tooth setting give clicks when it modulates, even at slow settings? I also noticed when the level reaches too low, it also clicks a tiny bit. Did i not notice this before?
-thanks in advance
my ring mod does not “click” at all but the whirring of the signal is annoying. you should get that bastard for ruining your wonderful and expensive piece of equipment.
i don’t get any type of clicks when i use the squarewave to modulate the frequency. the only time i get clicks is if i output the lfo into the carrier frequency jack, but that’s not what you’re describing.
sorry that it looks like a problem
well that sucks. I am not sure what could cause this, but it really is not that loud, and it only appears when I have the mix full on. oh well.
thanks for the replies
so does moog do repairs on these, and if so, how much?
thanks
no idea about the cost (i had one of my pedals fixed under warranty), but you can get in touch with them via the form on the mainpage. they give you an rma number and then you can mail it in.
