Once you start dreaming up new Moog gear, you cant stop (the same with buying Moog gear :unamused: ). As our son is still keeping us awake, Ive had some night hours to let the thoughts flow, and I thought about the two big Moog-related wishes: A polyphonic Moog and a new sort of Moog modular.
Maybe a new line of boxes, as wide as a cp-251 and as long as a Moogerfooger, could be an answer. This is how they could look like:
The first box has 4 individual voices with knobs for octave, frequency, waveform and level, rocker switches for hard sync and FM and jacks that double up on the knobs. With the jacks labeled âglobalâ you can control all four voices together, and the out jack gives you the mix of the four oscillators.
Use this as a drone-box or add four voices to your existing setup!
The second box offers 4 filters with the control possibilities of the MF-101, the Multidrive of the Sub Phatty and the HP/LP functionality of the Voyager. Again you can control all four filters together via the global jacks, and you can send a mix of four inputs through one filter via the mixer. The global output sums the output of the four individual filters.
Use this as your 4 VCFs for your 4 VCOs of the first box, or as a standalone filter bank!
The third box gives you 4 wide-ranged LFOs with continuously variable waveforms. Like on the voices box, one LFO can be hard synced to and/or FMed by the one before it. With the mixer you can use other CVs to shape your modulators. Maybe a noise-jack could be added in each section.
Use this as mod busses for your 4 VCOs and VCFs (and VCAs in the next box) or as great modulation (or even sound) sources for whatever you like!
The fourth and last box offers 4 individual envelopes and VCAs. The envelopes can loop (the loop knob controlling number of slowly decaying repeats) and the four outputs can be panned and appear as a stereo sound at the global output jack. Again you can control one or more parameters globally via the global jacks.
Use this as your last piece in the 4-voice polyphonic synthesizer, use it as the long awaited env/vca for your Foogertron or explore the interesting multi-stage-LFO you get with the envelope out!
Add to these four rackable boxes a 37-key controller keyboard with 8 individual outputs for gate, pitch, velocity and pressure, and some mixers and mults, and you can start having some serious polyphonic fun. When you have two of each box and a controller keyboard, you get an 8-voice, simple but effective polyphonic semi-modular synthesizer
If every box costs no more than 400-500 bucks, this should be a successâŚ
What do you think?
Greetings, radioland
