Running into an issue here -
I have midi clips in a track in Ableton playing patterns, which are in tern being output to the Mother32.
When I change clips, if the contain any Program Change information - the GLIDE setting on Mother32 seemingly gets cranked to full.
I can turn it down manually and then all is well.. until I change to another clip (with Program Change info) - the glide setting gets cranked again…
(There is no timecode being sent, so the sequencer is not starting/running.)
Has anyone else here come across this behavior?
