Prodigy replacement keys UK
Hi folks,
Does anyone know of a supplier that does Moog Prodigy replacement keys ideally in the UK/Europe. I need an E key… I bought one of a chap that did spares on eBay but it wasn’t the same type of key as they are on mine so I’m assuming I have an older or newer version that what they were for. The key I bought is to fit either Poly / Satellite / Minit / Multi / Micro / Mini so I’m thinking they may be the older version?
Any help would be grand.
Oh and I have a spare E key if anyone wants it!
Cheers
Try this guy - but make sure it’s the same as the one you want to replace as the Prodigy has 2 versions of keys, and the later version uses the same keys as the Korg MS20 - http://www.ebay.co.uk/itm/Moog-Prodigy-Poly-Satellite-Minit-Multi-Micro-Mini-Replacement-Key-/390635550654?var=&hash=item5af3b177be
These guys aren’t in the UK - http://syntaur.com/moog_prodigy.html - here you can see both versions.
Or… http://www.ebay.co.uk/itm/KORG-MS-WHITE-KEY-CLEANED-GREAT-CONDITION-/171954244819?hash=item2809458cd3
Regards - Tony
Thanks very much Tony. The MS-20 tip was what I needed. Look like my Prodigy is that type and that’s where I messed up the first time! Cheers
You’re welcome !
