Yesterday trying to update my Little Phatty Stage II to v3.21.690 I’ve got an error (Send Firmware Sx Code error 3), but finally the update was done
Now the bad part after the update:
-the pitch wheel doesn’t work “down”, and in “Up” position it has a very big range. Another strange thing is when you select a preset and play the keyboard the note is not in his tone, but if you use the pitch then it comes back to the right tone.
-The presets with mod/lfo/pitch don’t make the typical vibrato sound, it’s a very slow rate (sounds like a pitch down though, like it is set to its minimum rate value with maximum amount ). The Modulation knob is not working ok with lfo rate, it has a weird response, has not a sequential behaviour
-I’ve made a factory Reset but then the sounds are very strange with very strange names with symbols and so, these are not suppose to be the factory presets
I don’t know what to do
