I just got my Voyager last week and have noticed that when I turn the noise or ext switches on in the mixer the setting for OSC 3 ‘goes crazy’ in the LCD. What I mean is that the settings display for OSC 3 will rapidly change from off to on over and over while the audio stutters until I either turn OSC 3, EXT or NOISE off . My Voyager didn’t come with a manual but I skimmed through the pdf and couldn’t find anything about this. Any thoughts?
Not that I’m a Moog service tech or anything, but this looks like a bad solder point somewhere.
Definitely not what it should behave like.
Dom
You may not be a tech but you are correct. Moog tech says it sounds like a problem with the A/D converter on the digital board. So now I have to send it in. At least I had a week to play with it first.
Jon
Bummer!
But at least you can look forward to getting a faultless unit back.
Dom
