Hey Guys
I m a bit demotivated.
I keep on reading about Sub 37 problems, of all kind I must say.
I just unpack mine and I have a problem too.
It might be insignificant or irrelevant to most of you.
Specially with all serious issue I read about firmware update and midi.
As soon I connect the Sub 37 to my Tascam 122 start to bzzzzz…
I check and double check cables, but they are ok.
I also use them with my other Little Phatty and they are fine.
So the channels on my Tascam, they all works fine with the Little Phatty but
I keep on get the same noise with the Sub 37.
The Sub 37 works fine also with my amplifier …
You could try a hum eliminator. The wiring in my place sucks and some of my gear had a bad buzz, especially with USB connected. I use several of these from ebtech and it works great.
