problem with midi clock sync/weird pattern
hey guys,
I’m trying to sync the LP to a drum machine
using midi clock sync
It kinda works cause we’re able to change the lfo tempo of the LP using the
drum machine tap tempo. the only thing is that it does this really weird pattern instead of just following the drums.
the weird pattern starts when I press play on the drum machine and as
soon as I press stop, the lfo goes back to normal.
it seems like it could be just a midi setting on the phatty but I
sincerely think I tried everything.
it’s really frustrating cause it used to work fine, and I used it a lot.
dont know what happened,
any ideas ?
thanks a lot !
