power consumption
hi,
i’d like to know whats the minimoog voyager eletric blue power consumption
Should be on the label on the back of the Voyager. Required by UL.
If you check the UL label on a Voyager you can see that it is rated for 40 watts. Mine operates off of a steady 18 watts, and 20 watts with the backlight fully on. Naturally, this would be higher with a lamp attached.
I measured this on my Kill-A-Watt (http://en.wikipedia.org/wiki/Kill_A_Watt).
