Possible to link two MF-104z's together?
Can the MF-104z be synced to tempo in any way? If so, is it possible to tempo sync two Moogerfooger delays together and still retain independent control of the delay time for stereo effects?
The MP-201 might give you this functionality.
Basically, you’ll need something that converts tempo information into a fixed voltage. I imagine the way that it would work is that you’d set the Delay knob on the 104 to the minimum value and then calibrate the voltage for specific tempos from there. Ideally, the MP-201 could do this with tap tempo, MIDI tempo, etc.
I haven’t heard from Moog if this is something they plan to offer. They are doing tap tempo and MIDI tempo to set LFO speeds, so tap tempo and MIDI tempo for a fixed voltage for delay time definitely seems doable.
Bryan
Thanks for the info Bryan.
If they ever implement this feature I will have to bite the bullet and snatch up two MF-104z’s for sure. The possibilities of having true stereo delay effects out of those bad boys would just be too good to pass up!
