Not quite as good as the knife idea but…you do have the V trig gate input on the back. Just tie it to something that puts out 5V - - maybe a pedal you already have or a modular component?
at least, it is possible to achieve the effect. I’ll try it
…that also means it would be fairly easy to do internally, with a switch. if one were so inclined. tap 5v from somewhere and feed it to the V trig point.
I wonder if that’s how it’s wired on the Voyager?
not nearly as glamorous as a knife, though!!
ps I saw some keyboard weights displayed at knobcon. good idea, but do they also work on black keys?
Simple sent a MIDI note to the reissue Minimoog and then pull the MIDI cable while the note is held. This way, the Minimoog will be “key on” until you switch it off.
