Poly Moorgan
so here is something i drawn a while a go and didnt finished it.
its an idea for a new polymoog, its like a voyager mixed up with a organ.
so to start im going to talk about the filter, it has a low pass and high pass instead of just one knob. it has the old and new resonance options the old would be like a polymoog resonance with 3 points for resonance to work, and the new is a voyager like.
next is what i called the Free Oscillator. it has many options for you to chose how it will work: on/off , split/full to chose if it will be acting just in half of the keyboard or full, high key/low key thats to chose if it will be following the higest key or the lowest one, so if the split its turned on and high key on the lower half of moorgan will play only chords or notes tat you whant while the high part will play the free oscilator as a monophonic, the same happens as split and low key, the the low keys would be like a mono bass and the other half would play the moorgan section. there is the high freequency and low freequency just like the third osc from voyager and there is also the kb count on/off if that is turned on the moorgan will have the free oscilator following the lowest or highest note on the keyboard while if turned off it will just sound there and u can mix it or not or use it just for modulation, its like the third oscillator in the voyager but with some intresting polyphonic usable functions.
Then there is the drawbar section, well this section has 9 drawbars and they work as the mixer in the Moorgan, and the last of then its the free oscilator drawbar. Under each drawbar except for the last one there is a wave option, so u have like an organ but with choosable wave forms having a sine of corse and all the opther ones saw thoot, triangle, etc…
and there is the modulation section like is the voyager XL.
So thats it i dont know i just feel like there is no actual fun and modulatable polyphonic synths and that was my idea for it
Check the pdf to see the draw
thx
Nice job on the mock-up.
Additive and subtractive synthesis all in one.
