Can someone explain exactly how volume control works when chaining multiple Phattys in poly mode? I have LP → SP → SP as my setup, and I would ideally like all voices at the same volume level, controllable by the Volume control on the Little Phatty. Is this possible?
if your LP is a Stage/Stage II, should be no problem. Just go to the Master menu, MIDI setup, and make sure “Send CC:” is set to ALL. This will ensure that the LP Volume knob sends CC 7 (Volume). The Slims will respond to this. If your LP keyboard is a Tribute Edition, this won’t work, as the Tribute Edition volume knob is purely analog and doesn’t send any MIDI.
