Hello, just today my year old or so Sub 37 started making noise when I switched it on. It sounds like interference with a whistling sound. It disappears as soon as I hit a key. Now, this only seems to happen with presets I either made or took from the new Editor library. The factory ones do not seem to do it. And it is only one patch that I created that does it real badly; however a few more that I took from the library sound “crunchy” until I press a key and then they sound right. I re-installed OS 1.2 with no luck. Absolutely nothing has changed in my setup. It’s in the machine somehow. I hope this can be cleared up without physical repairs!
Also, how can I turn the non-factory presets into init presets and start over? Maybe that’s all I need?
Thank you
