playing over loops on the LP
is it possible to create a loop with arpeggiator then play over the top of it just using the funtions on the Little Phatty or do you need a looping pedal ?
You would need a looping pedal, or multitrack it.
The synth is monophonic, so it can only play 1 note at a time… therefore if you tried to play over top of it, it would just steal notes from the arpeggio… though on the lp if you latch the arpeggiator and play a new note, it will just arpeggiate that new note… so, no, u can’t do that. Looping pedal, or just record 2 tracks with multitracking software.
dumb question seeing that it’s monophonic, duh… thanks
