Pitch wheel tight and keyboard mode ?
I got a 2nd hand voyager. The pitch wheel is very tight compared to my Old School. Is it normal that they have some differences?
Also, Is the midi version of the voyager default to have note priority set at low. I have gotten used to the old school which is set at “last note” played. I want to change it globally, because individually will be a pain in the hump.
Finally, is there a diagnostic that one can run to make sure the second handers are in tip top shape?
…simplified:
  1. Can the tightness of the pitch wheel be adjusted, that is, how hard it is to move it up and down?
  2. Can the note priority be changed globally or one patch at a time?
Me too. The Voyager wheels are STIFF!
  1. Note Priority is saved per patch. There is no global setting for this. I wish there were.
    However, if you have the software editor I believe you can select all the presets, go into the feature called “Single Parameter Adjustment” under the ‘Bank’ drop down and change them all to last key. Then just resend them to the Voyager
