pitch drift moogerfooger / micromoog CV
I want to control my Doepfer A-100 system via a micromoog and use an extra oscillator
via the moogerfooger freqbox… The micro has a very convenient keyboard out jack that sends CV.
Does anyone know how to adjust the slight difference of intonation between e.g.
Doepfer A-110 oscillator compared to a moogerfooger oscillator (e.g. in the
freqbox)? If I tune it at the lowest pitch the freqbox gets gradually out of tune going
up a couple of octaves.
I have the same problem with my old micromoog vs the A-110. (but worse)
Also - the S-trigg signal is inverted on the moog and at a higher voltage (12v I
believe). Actually, the micro is quite out of tune with itself. Is there any pot to adjust inside the micro (voltage per octave adjustment)?
The doopfer uses 1v/oktave - I believe the moog uses a smaller voltage per octave.
Any ideas would be greatly appreciated.
