hallo everybody,
probably been asked a lot of times, so i’ll also have to do:
is there a way to adjust the pitchbendamount of the presets like 1oct etc.
this as , when i set him to 1 oct he gives me something like 13halves up and 'bout 12 down.
or should i be content with the 1 free ssignable slot.
second question: small scatch on touchscreen, no problem but i feel it ( probably a nailproblem)
any idea of fixing it ( glue or polishing that little piece??)? any experience welcomed.
fr.gr sunny
I don’t know of a way right off hand to change the pitch bend amount, but its there and I don’t know if you can specify like X wholesteps here and Y halfsteps here.
I also think that we have pretty much concluded that the touch surface is just one of those things that gets scratched with normal use.
Mine just developed a mark that I hadn’t noticed before…and you are talking to someone who is meticulous.
thank you , i’ll drop a tear on it and continue playing.
with the pitchbend i found out that probably i’ll need some hardwarefix + that in manualversion 2.5 there is a callibrationfunction to try first. however where can i find that manual, on the moogsite there are only the newer versions. afcourse i can mail them , however it might also be that i overlook something.
thank you, did it, now it shows 0 , although when checking with a strobetuner it still jumps 1/2 note when moving + the standardpresetvalues don’t match their label ( 1 oct =13halfnotes, the free assignable one is tuned properly though).
anyway, thanks again, will definitively have the hardware modified on this subject.
by the way while opened the pitchwheel department , i also tried the" remove the spring" trick: the pitch wheel functioned well enough for me, but due to the fact that no click is felt when reaching the middle position , i had to resore it to the original state. (afcourse a mod could be made underneed the wheel with some little pieces of iron/spring but i didn’t have time and patients for that now)
