I really want to be able to turn off the phatty’s arp retrigger when using MIDI clock, so I could play in time arpeggios or should I said on beat.
Is this possible?
Is this possible?
Would be a handsome feature to Moog’s arpeggiators, but at present, disabling the retriggering of the arpeggiator is not possible. The only way to achieve this would be using an arpeggiating piece of soft/hardware that can.
You could simply program the arpeggio into your DAW note-by-note using the divisions and BPM you have set on the SP arpeggiator. Of course, you’ll miss out on that sweet legato glide that can give arpeggiations a more genuine/less programmed sound.
Damn!
I really love the arp… Still I can play legato, and if I get the sync with first chord there is no problem… but sometimes is just so hard to do this… Another thing that would be useful is note on when you turn arp off.
I want to avoid arpeggios in software as much as possible.
Phatty is a great synth, but some things must be updated!!!
Amos!!!
