Phatty VST Editor update? Any good?
I just received an email informing me of a new update to the VST editor. I’m away from my toys today, so won’t get a chance to check it out. I’d be very interested in hearing everyones opinions on it, particularly how it performs with windows/ableton.
If you can get it to work let me know.
Have tried everything I can think of but cannot get it to send midi messages to the Phatty. In the top corner of Live the box lights up to say that MIDI is being sent when I twist the dials on the VST but nothing goes.
I could get the old editor to work, send patch changes, control the filter etc but for this new version, nothing
Hey Guys,
Where is the latest VST Editor available from?
The Moog website has the older version and the Rekon Audio site doesn’t have a link either.
Cheers - Pete
I was sent a link from MOOG over the weekend.
Had a link and updated license key
IMPORTANT DAW HOST SETUP INSTRUCTIONS:
When using the VST or Audio Unit version of this software you will need to setup your MIDI ports in your DAW host so that there are no conflicts between the VST-AU Little Phatty Editor and the DAW host. In particular, you will need to disable the MIDI Input and Output ports in the DAW host’s MIDI setup for the ports that you plan to use to connect the VST-AU Little Phatty Editor to the synth. This allows the VST-AU Little Phatty Editor to access these ports directly from the Editor.
see also MIDI SETUP on page 11 of the .pdf manual included with the new editor…
