I really just need to know if the voyager can make the same type of sync sound as the phatty, with only 2 ocs, hard synced, and attack as fast as it goes.
It should on paper,
also If you run the output , back in trick, will the overload sound similar?
I cant afford to have both, There are only 3 patches I really use on the phatty and they are all hard sync with a little overload.
I guess I want to know if the osc’s and envelopes sound as fat and punchy on the voyager, mostly with 2 osc sounds.
I’ve never played a Lil’ Phatty. However, I’ve got a Voyager and use the sync sounds quite a bit. I also use the feedback trick from time-to-time and it works as expected.
In short, the Voyager will do what you are asking.
Well, the phatty is pretty limited for the types of sound I want, what it does, it does well but gets very boring, no stereo out so the sound can move, no dedicated noise, no third osc…kind of very boring to program at times, but I do love the overload, without that it wouldn’t be exciting at all.
If I need a smooth sound the voyager has me covered, I just want to make sure it can replace that one sound the phatty does very well for me.
