Phaser hum
I’m having a ground loop hum problem when using MF-103 in stereo (audio and aux outs at the same time).
I’m using quality TS cables. The hum is not there when only one out is plugged in.
Anyone experienced this?
Nope can’t say that I do. Are you going into two amps, mixer, one amp with stereo inputs? Not really sure what would cause that, i’ve run my phaser in each of the connections above and haven’t heard any notable hum. Does the hum happen when its bypassed or just actived?
Probably a ground loop between your two amps or destinations. What happens to the signal after the 103 audio/aux out?
The signal goes into a TC Electronic Konnekt Live audio interface. Seems like a ground loop.
Can you use blind T(R)S cables?
Or disconnect the shield of one of the pair? (At one end only, the connection is still shielded.) You should only need one reference to ground from unit to unit.
