pedal assignation
Hello,
I want to use an expression pedal, but it is always assign to the volume level, and I want to use it for amount filter. I don’t find the solution in edit mode, please help me.
Elliot
Do you know how to program modulation via the mod busses?
What do you want to use an expression pedal to achieve?
In fact I use my voyager rme on stage and I play others keyboards to. So I would like to change the amount-filter with a cv pedal. When I plug it into my moog the default is volume control and I want to change that.
And I ask myself if it’s possible to have different parameter between the preset (edit) or if it’s only possible for the master.
