Just had a question concerning the panning of the filters on the MF-105M.
I know that the odd-numbered filters are send to the left channel and the even-numbered filters are send to the right channel.
But is there a possibility to change this (with a jumper f.i.) so that all filters are send out on both channels without the left/right effect ?
Maybe for this only use the left output? Or do you have something else in mind?
I have the right channel normalled to the left channel on my patchbay, but since the bypassed signal will only be sent to the left jack, the bypass level is half the volume of the effect on level.
I should probably change the jumper over to make both channels sound in bypass mode.
Good answer…didn’t think of that one…
I always think in stereo signals iso. of also using the mono out.
The thing is that i always use the MF-105M wet/as a effect send a return for different instruments on my mixer…so i am not using the bypassed signal in any way as this will create a echo like sound.
Therefor i use a mono aux as send and a stereo channel as a return as this is the only one left on my mixer…
Maybe i could pan the channels to the center iso. extreme left and right…?
