Panel settings after power off
Hey,
Are the front panel settings saved if I turn the electric blue (with keys) off? when nezt I turn it on, will it bring up the exact same sound it had before I turned it off?
I had to run out of he studio, and didn’t have time to save the patch.
Yeah, I think that as long as you didn’t use any menu diving in the making of your patch, it should stay the same.
Thanks for the reply!
Yea.. eventually, I figured it out the hard way (i.e., crossed fingers and hit the switch). Even though for some reason, OSC 1 wasn’t playing when I turned the Voyager back on, and it didn’t respond to volume changes in the mixer either. It started playing again only when I had the mod wheel all the way up (even w/ the modulation amount at zero). I triple-checked the signal path, and there was nothing that was supposedly causing this. Perhaps it was some of the software settings that the patch I modified had - I don’t know.
Oh well.. at least it works now.
