Out of tune
Yelloh,
Just got myself a LP, and I was wandering that it is normal when I power up the LP, it is heavily out of tune. Is this a usual problem or not? I checked the autotune parameter in the menu but everything seems normal. So now, every time when I start up my LP, I’ve to tweak it manually. I’m sure there must be a reason to avoid this problem, so I hope somebody can help me out.
Cheers
Louis
yes thats normal. it takes 10-15 minutes for the oscillators to warm up and stablize
Cheers
DL
It is normal for analog to be out if tune at first, but teh LP should be pretty stable after a few minutes. Once the LP has wamed up for a few minutes does the auto tune work then, or do you have ti keep manually adjusting it ?
If you haven’t read the fine manual (RTFM) and how to run a calibration on the LP. Easy to do and wiil not take much time. Befroe running it though let the LP warm up for about 30 minutes.
Have fun
Thx for the reply and tips!
L
