Sub 37 Editor 0.9.28
Install on 2015-12-31
I’m on a MacBook Pro, running OS X 10.11.2.
Here’s my experience with installing 0.9.28, with listings to show you what happens. It’s a novella.
I unpack the zip file, run the pkg file, answer the questions, and the application gets installed into “/Applications”, and a directory structure and some files get put into the user’s “Library/Application Support” directory.
I’m going to the shell (aka Terminal) to show you whats going on. For these listings, the user is “abc” in group “staff”, and the admin installer is “xxyyzz” in group “admin”.
After the installation of 0.9.28, the user’s “Library/Application Support” directory contains a new “Moog Music Inc.” directory – but it is owned by the administrator, not the user:
$ cd /Users/abc/Library/Application Support
$ ls -ld Moog\ Music\ Inc.
drwxr-xr-x 3 xxyyzz admin 102 Dec 29 15:53 Moog Music Inc./
Here is the contents of the new “Sub37” directory:
$ cd Moog*
$ ls -l Sub37
total 7448
drwxrwxr-x 2 xxyyzz admin 68 Dec 29 15:53 Hardware bank/
-rw-r--r-- 1 xxyyzz admin 810 Dec 13 2013 PresetCategories.xml
drwxrwxr-x 4 xxyyzz admin 136 Dec 29 15:53 Presets Library/
-rw-r--r-- 1 xxyyzz admin 1923816 Nov 11 11:25 Sub37 MidiPortHandler(x64).exe
-rw-r--r-- 1 xxyyzz admin 1882856 Nov 11 11:25 Sub37 MidiPortHandler(x86).exe
Everything is owned by the administrator, and the user can only read the setup files, and cannot write into the hardware bank (?) and the presets library.
Also note the two unnecessary Windows “exe” files.
Here’s the contents of the new Presets directory:
$ ls -l Sub37/Presets\ Library/
total 128
drwxr-xr-x 96 xxyyzz admin 3264 Feb 22 2014 Factory Presets/
-rw-r--r-- 1 xxyyzz admin 62899 Dec 10 03:13 Factory Presets.zip
And let’s look at some of the “Factory Presets”:
$ ls -l Sub37/Presets\ Library/Factory\ Presets/Tau*
-rw-r--r-- 1 xxyyzz admin 381 Dec 9 2013 Sub37/Presets Library/Factory Presets/Taurus I.syx
-rw-r--r-- 1 xxyyzz admin 381 Dec 9 2013 Sub37/Presets Library/Factory Presets/Taurus III Bass.syx
-rw-r--r-- 1 xxyyzz admin 381 Dec 9 2013 Sub37/Presets Library/Factory Presets/Taurus III Tuba.syx
-rw-r--r-- 1 xxyyzz admin 381 Dec 9 2013 Sub37/Presets Library/Factory Presets/Taurus III.syx
These are sys-ex files, but their headers are not Sub37 headers. I’m guessing that they’re for some version of the Taurus.
An additional problem: the “PresetCategories.xml” file has categories for some other device, not the Sub37 (see the date-stamp: 2013? for the Sub37?)
At this point, when running the standalone editor, not much works. The categories list shows only “All”, and none of the drop-down selection menus work in the various panels. You can tell it to fetch the presets from the Sub37, and it will do so. But after they’ve been downloaded, the application hangs, leaving the progress bar at 100%. I’m guessing that it’s because the user doesn’t have permission to write into the directories that the application installer created.
I have worked around this problem by going to the shell and fixing the ownership of the directories and files. In effect, something like this:
cd "Library/Application Support"
sudo chown -R my-user-name Moog*
chgrp -R staff Moog*
But since the standalone editor is happy with re-creating missing files and directories, then just wiping out the entire “Moog” directory might be good enough to fix this.
On OS X, getting to the library is a little tricky, since the Finder wants to hide it from us. Just bring up a Finder window, click on Go in the menu-bar, hold down the Option key, and the “Library” entry will appear in the drop-down menu. Click on it, to go to the library folder. Go into “Application Support”, find the “Moog Music Inc.” folder, and delete it.
Here’s what I get after doing that (well, actually from the shell), and starting up the application again:
$ cd Library/Application Support
$ ls -ld Moog*
drwxr-xr-x 3 abc staff 102 Dec 31 18:51 Moog Music Inc.
$ ls -l Moog*/Sub37
total 40
drwxr-xr-x 258 abc staff 8772 Dec 31 19:10 Hardware bank
-rw-r--r-- 1 abc staff 729 Dec 31 18:51 PresetCategories.xml
drwxr-xr-x 4 abc staff 136 Dec 31 18:51 Presets Library
-rw-r--r-- 1 abc staff 4697 Dec 31 19:07 Sub37 Editor Standalone.prefs
-rw-r--r-- 1 abc staff 4132 Dec 31 18:51 Sub37 Editor.prefs
When the editor is started, it says that it needs to get the presets from the Sub37, we say “yes”, it downloads stuff, and woo-hoo! the Hardware Presets column is filled with yummy moogy goodness.
The Categories drop-down appears OK, too.
