OSC 3 can't be turned off
If I start from a presets, not the default template on my Voyager RME and I want to turn of osc 3, it keeps leaking.
I turn my OSC 3 volume all they way down and can still hear it, turning off OSC 3 wont change anything. The only way to kill it is to turn osc3 to LO mode. Very strange thing, I don’t understand.
This is on the 3.4 OS Voyager RME
is there a chance osc 3 is routed to modulate the filter on those patches?
Sometimes ive noticed that if you have the volume super loud or the headphone volume super loud running it into something that is going to boost the signal, then you will hear some leakage.
But its nothing that has happened to me on normal volume levels.
Is this something that you have turned the switches off, turned their levels down, turned the volume down and still hear it? Is this an osc sound that can hear a difference if you mess with the filter cutoff? Is this something that is affected by the volume envelope settings? Does the oscillator function just as it normally would only that it is leaking where it shouldn’t?
