OS 2 Problem: no MIDI note on
After upgrading to the new OS 2, my Voyager no longer responds to MIDI note on messages. Of course I switched MIDI IN to On in the Master menu
and the Voyager does respond to MIDI program changes, and the MIDI LED on the front panel even blinks as the Voyager receives MIDI data. I’ve also fooled around w/the Velocity Curve and the MIDI merge functions thinking one of these could somehow be the culprit, but no dice. I’ve also run all the normal troubleshooting tests from my sequencer, and I’m positive the Voyager is receiving note on messages. The other varialbe is that I installed the VX-351 yesterday, but I doubt this had any effect since I did the installation extremely carefully.
Has anyone else had this problem? I hope it’s my error and not a bug in the OS, because that’s a serious bug.
I’d appreciate any help or comments.
The source of the problem was that the “MIDI KEY” function in the master menu was activated by default. This renders the voyager unable to respond to MIDI note on functions. I simply deactivated this function and the voyager now responds to all MIDI messages. Hope this helps someone besides me…
