os 2.5 HELP PLEASE!!
howdie all
i just upgraded my mmv os to 2.5 and in the process have lost the ability to trigger from cubase. the notes go to the mmv (the red midi light goes on/off) but no sound from the mmv ive checked the voyager all the midi in/out are on. (and cables are obviously connected)
i have no idea. especially because before this, i was running 2.4 and had no troubles with controlling the moog.
any help would be greatly appreciated
go to the MASTER menu.
Find the item “MIDI Key Order” and set it to “is not active”.
You might also set the “MIDI Merge Func.” to off in the MASTER menu. Depending on your set up you might get a MIDI loop by using the merge function.
And set the “MIDI In Channnel” of the MASTER menu to the channel number you send from Cubase to the Voyager.
