one note delay problem
Hey all I’m a Moog novice and my Little Phatty II has a weird one note delay on every sound including having done a master reboot and factory setting reset. So i play a not and split second later the exact note is repeated though quieter.
Its driving mew crazy and makes the synth unusable. Using an arpeggiator makes it absolute chaos.
Any ideas please?
Try using the headphones and turn of the amp you use. Is it better now?
Pull the MIDI and USB cables and try again. Is it still like this?
have you checked to see if poly-chain mode is on?
Hi thanks for your reply and apologies for the delay getting back. I’m not using usb or midi cables but through the headphone socket you are right its ok. I’m using one jack to jack lead to a mackie mixing desk. Any ideas if it is a programmable function I can change? I hoped a factory reset would do it.
If it is allright on the headphones, the problem is somewhere in the mixer. Maybe some FX there?
