I just got my LP Stage II today, and I was playing with it, and noticed that the amber octave light when you go up one octave doesn’t illuminate. Does anyone else have this problem? Will I have to send it back to Moog to be replaced, or can I take it to the dealer here in town?
(ARGH)
Now that you mention it, mine may have the same problem. I say this 'cause it struck me as strange that the octave lights were off when I first powered it up, and after a factory reset. I seem to recall all the other LPs I’ve played being up or down an octave by default. I’ll check when I get a chance.
Your dealer should be willing to replace it. That said, I’m on my second LP with problems. At this point I’d really like Moog Music to ship me a new replacement direct.
P.S.
I’m not surprised the economy is tanking: I just received my third faulty replacement Eventide H8000FW yesterday from MF. The first one was crushed by UPS, the second one had a large scratch on the faceplate, and now this one gives me an “analog board failed” error when I boot it up. I haven’t heard back from Eventide yet. It is the holidays, so…
And, to add insult to injury, I’m on my third Waldorf Blofeld with the lettering/paint litterally rubbing/flaking off. Fortunatley the US distributer is being kind enough to ship me a non-defective Blofeld direct.
Update: it didn’t work at first, but I powered down the LP for a bit, then came back to show it to my dad, and all of the sudden, it worked. Maybe it just stuck because it was the first time I used it. I’ll check it again later today and report.
So I checked again, and it seems to go on and off as I play, like there’s a loose wire inside. I might have to take it over to the Moog dealer in town to ask them.
Anyone else have this problem?
Aside from the fact that one should expect first quality products when they pay for them, the LED and the LCD could be symptoms of a larger underlying problem. Play it safe. Get a replacement.
What happens when you go up or down two octaves ? “Normal range” the LEDS are not on, it is only when you go up or down. In case you don’t know the octave setting is stored as part of the patch. If it had been working fine and just strated doing this call tech support.
As long as I can enjoy the instrument I’m fine with it.
I have SCI DrumTraks which after a gig with a MASSIVE soundsystem started to make a humming sound. I can work around it so I’m not really bothered by it. I could send it to a technician to fix the problem but I’m not interested in missing the instruments for a couple of weeks.
I am not saying there may or may not be a problem . Some of the factory presets are saved as 1 oct up or down, if it is doing it on all then yes there may be a problem… if it is blinking on and off as you play then yes there maybe a problem. :0 If I’ve miss read somewhere, sorry
I am not near mine right now or manual, I don’t recall there being a LCD Contrast adjustment in the menus, call tech support, it shouldn’t be “that dark”
