GilW
February 29, 2016, 7:17pm
1
Please see Editor 0.9.45:
Windows: http://www.moogconnect.net/downloads/sub37/Moog_Sub_37_Editor-0.9.45-WINDOWS.zip
OSX: http://www.moogconnect.net/downloads/sub37/Moog_Sub_37_Editor-0.9.45-OSX.zip
UPADTE — New firmware 1.1.25:
http://www.moogconnect.net/downloads/sub37/Sub_37_Firmware_v1_1_25.zip
OSX users please install manually at this point.
Fixes:
#546: Clicking INIT PRESET, the panel switches to init preset settings and then back to previous preset
#563: Preset and Category menu not fully populated as VST OSX
#560: Midiporthandler file version should be set to 1.0.0
#557: Trivial typo on the missing presets message
Keep on checking this out please, we expect one more firmware update and then should start final regression.
Thanks all !
Ndoe
February 29, 2016, 7:42pm
2
Still happening in this build
Ndoe:
I had mentioned this in a previous post and did some further investigation
All of the other AU and VST i have operate the same with the mouse or a hardware knob midi synced. Ableton will bring the parameter I am adjusting to the front. It works on my rob papen, NI and others. So the VST sub 37 Editor doesn’t function the same as AU plugin in that manner.
I will post a video to show an example of the two below to help understand what i mean:
I also noticed in both the VST and AU version if i enter in 3 automation lanes in Live i.e ( cutoff, res, mod 2 filter amt) the main channel lanes will flash between the different automation lanes. In the video I have 5 lane of automation
https://youtu.be/Tmb38Ww_P9A
While doing this test i noticed it i edit the automation while it is playing ableton stops picking up the movements on the synth. It will still record midi cc in the individual clips but it stops picking up automation. Looks like if i draw in 3-5 separate lanes is when it loses “connection” almost every time. I can still use the mouse to draw in envelopes and the sub reacts to it so it is receiving the automation. Mid way through on this video when the automation line jumps i am moving other knobs so it is reading that i am moving other knobs, but the automation line stops moving.
https://youtu.be/bhzV7Uq5o0c
pb21
March 1, 2016, 2:19pm
3
The firmware updater failed to update on the 1.1.25, it recognised 1.1.24 and saw the new firmware but hung, ive proceeded to do it manually.
GilW
March 1, 2016, 3:05pm
4
Thanks pb21. I’m missing your setup information in your signature. Are you using OSX or Windows ?
me too, fail run app
macbook pro 13 yosemite 10.10.5 direct usb
i’ll try manualy
GilW
March 1, 2016, 6:00pm
6
Please use manual install in OSX, 1.1.25 is known not to trigger.
hoegge
March 1, 2016, 9:28pm
7
The 1.1.25 FW installer does not even start (the application) on El Capitan
GilW
March 1, 2016, 9:30pm
8
Known (and mentioned in the original post).
Will post a working updater soon.
