Note Triggering - "dropped" notes? Envelope wierd
I am having a little trouble with programming staccato sorts of basslines. Seems that from time to time, I will “drop” a note or find it to be muffled when triggering a pattern with several 16th notes in a row. This seems to happen on factory patches as well as my own.
I have fiddled with the Amp/VCF envelopes and adjusted the DSR segments accordingly. I have also set the Kbd Trigger to “Multi” (and back to single). To me, it’s a relatively simple thing but I still cannot achieve the nice, tight (and relatively simple) bassline that I am looking for.
I have even tried the option that drops the “Release” portion of the envelope - no luck, but I do not think this should be used in my patch anyway.
Anything else I may have overlooked?? Is this a “known issue”?? I am running System Version 2.6
THANKS!!
d.
Is glide turned on? if so, try turning it off.
Do you play the Voyager from its own keyboard action or via midi ?
I had also tried turning the glide rate to “zero”. Have yet to see about disabling it within the patch.
Triggering notes via MIDI from Ableton Live, Till.
Again, my apologies about the duplicate posts.
I will see if I can edit/remove them.
