Note-Synce ON
minitaur is my first synth, and im note quiet cetting the whole midi/cc issue… how to i turn on note-sync and leave it on for default?
Do you have a MIDI controller? Easiest way would be to assign the ‘Note Sync’ CC# (CC#81 according to the manual (page 22)) to a knob or slider on the controller. Then you can control it’s state with this control. The range of the control will be 0-127. 0-63 = Note Sync OFF, 64-127 = Note Sync ON.
how do you assign a cc?
There is no way to leave it on as a “default” - meaning every time you turn on the unit it’s automatically on…
however it’s easy to turn on using the Minitaur Editor and you can save presets in the Editor that have Note Sync enabled.
Or in your DAW or sequencer if you’re using one, put the appropriate MIDI CC message at the beginning of the MIDI track that is controlling the Minitaur.
Depends on what controller you have. Check the manual. Should be easy to do :wink:
Sorry to change the topic for a second, but this is the 2nd time I’ve seen someone say something about turning the Minitaur on/off. How are you all doing so?
I just plug it in to turn it on, and unplug it to turn it off.
