I came up with a great sound using the lfo out on my 103 into the freq. of the 107 but Im getting a hum. It sound s like a ground hum and it makes the sound un useable. Has anyone else experienced this?
Try turning the Drive down a bit on the 103. If the noise persists, try using a higher quality cable. If that doesn’t help, play around with different settings on both 'Foogers, paying special attention to the Drive and Output levels. Hope this helps! ![]()
I tried all of that. Its not a normal noise you would get with bad cables or anything its just a noise that happens when the lfo is going to the frequency in.
