No blockers in 0.9.47 ?
Hola !
We haven’t read about any real blockers in the final candidate, does it mean everybody believe it’s good enough for release ? :wink:
Have a great weekend !
Hi Gil, all seems good to me, hope you and everybody else have a good weekend too, you all deserve it forthe great setup you have provided for us subbies. Cheers Glyn.
I cant use it for anything good other than saving pre sets
automation dose not work for at all
I’m not sure what you mean,
  • Can you save presets ?
  • What else does not work besides the more-than-3 lanes Ableton automation issue you have mentioned ?
  • Can’t you automate at all ? What are the circumstances ?
Question is about bugs and functionality. As useful (or not) as one may find it…
It works perfect for saving presets!
I don’t really no what to say tho, to me if I cant use automation why would I use an editor. I have 2 other editors that i can save and load sounds, but I can run automation.
one of thos is the minitaur editor, it works as it should for automation, can have as many automation line as I need.
it doesn’t grey out any of the automation line and it doesn’t go out for tune if I move any of the controls like sustain on the editor.
The other editor is by codeknobs for the Dave smith Tetra, the tetra editor is probably the best editor I have used for a hardware synth, and he has nothing to do with the dave smith company
http://codeknobs.com/products.php?id=2
I make electronic music, so most of the time I will need to run a lot more than 2 or 3 automation lines. Think I going to try it with out the midi driver, using the windows driver with the usb and midi cable combernation like I do minitaur, and see if this helps me.
Hi Gil,
For me personally, I think it’s stable enough for release. Admittedly, I’m not a software “power user”, but for my needs, it’s perfect.
BTW, were you able to look at the knob “calibration” issue I mentioned a few days ago?
Thanks for the great work!
and of course the benefit of releasing it is you will get more data samples as regards to its stability in multiple system configurations.
Nuendo 7.0.35 - Mac 10.8.5: Everything is looking fine! :sunglasses:
On a personal note, I would say that this VST Editor is more stable and elegant than Voyager PlugSE 64… (which to be fair is very good in Standalone Mode)
