Do the newer CP-251s with active attenuators (white rings around the black jacks that have +5V for pedals) allow the following?
I like to invert the keyboard CV back into filter cutoff (like the CP manual suggests) for duller high note sounds…presently I use key CV into an input on the mixer (EP-2 into another input) but then I take the - output back to the Filter input on the Voyager…the only bummer is I need to use the mixers on both of my CP-251s (older red jack ones) to be able to have a normal toe-opens filter/heel-closes filter pedal action…
If I used the “active” attenuator set to -5 position, would that invert my keyboard CV???
