Let me start by saying this is my first analog synth.. I bought it used and as soon as I brought it home, first thing I did was update it to Firmware 2.1.1 and installed editor 3.0.
Here is what the Minitaur is doing:
When I plug in the minitaur to my computer via USB everything looks good. The standalone Editor changes as I move the dials on the synth. However the sound does not change.. some things like the cutoff does work, but the setting ‘restores’ itself on the Editor to whatever it was when I launched the editor. And so for a little bit (a second or two) the sound changes to reflect the change I make on the synth, but the editor forces the settings to go back to the state it was on the Editor (and not reflect the change that is actually on the synth).
I hope that makes sense… can anyone guide me in the right direction as to what I might be doing wrong? Is the Firmware not compatible with the version of Minitaur that I have?
Have you selected the Minitaur in the Editor Setup Settings as MIDI Input and MIDI Output?
Do you have other MIDI related software opened on your computer while doing so?
And no MIDI connection at the same time as the USB for test?
FOLLOWING ARE TWO SETUPS I’VE TRIED WITH THE PROBLEMS ASSOCIATED BELOW EACH SETUP:
Setup 1:
Axiom 25 MIDI out to Minitaur MIDI in
Minitaur audio OUT to a channel on the Mackie Mixer
Mackie audio OUT to Scarlett Audio interface IN
Of course Scarlett Audio Interface is plugged into the PC
NO USB from Minitaur to PC
Problem:
No sound from the Minitaur at all when I play any notes on the MIDI controller. I do get sound from other inputs in the mixer so its not the mixer… and in the setup below I do get sound from the Minitaur but not in this setup.
Setup 2:
Focusrite Scarlett Audio Interface MIDI out to Minitaur MIDI in
Minitaur USB to PC
Problem:
When I plug in the minitaur to my computer via USB everything looks good. The standalone Editor changes as I move the dials on the synth. However the sound does not change.. some things like the cutoff does change, but the setting ‘restores’ itself on the Editor to whatever it was when I launched the editor. And so for a little bit (a second or two) the sound changes to reflect the change I make on the synth, but the editor forces the settings to go back to the state it was on the Editor (and not reflect the change that is actually on the synth).
