New OS 2.0 - CC MIDI Filter
Hello,
Lately I’ve been using the LP with external sequencers and arpeggiators, and I have found the need to have a way to block certain CC numbers to be received to the little phatty. I.E, I use the Korg Karma Arpeggiator and this machine sends many CCs at the same time, and I found that the Karma Arp sends CCs #10, #16, which in turn changes the Osc2 Freq and Osc2 Level. This makes the Arpeggiator useless, unless you engage the osc sync button on the LP, but this limits the sound palette you can use with the LP.
Hopefully there still chance to include this feature on the new OS.
EDIT: I could use the MIDI filter on my computer sequencer to avoid receiving this CCs, but in a live situation it would be invaluable to have this feature on the Little Phatty itself.
Regards,
I would expect that you could edit the Karma patterns to send/not send only the CC#'s you want. Is this not so? Paging Stephen Kay… :slight_smile:
