New MoogerFooger Files
I was playing in the studio for awhile this evening and recorded some quick things using a MiniMoog Voyager, MF 107 FreqBox, MF103 Phase Shifter and MF101 Low Pass Filter. The tree files can be found on MoogSpace.
and for crying out loud>now there finally are new files again, plus (its a miracle) the moogler is here, AND NOW I HAVE TO PAY 12,95 suddenly!!
i thought paying wasnt necessary yet.
I try to view some moogler files, but I can´t. Its start to open, then a log in windows appears. I put my Moogspace user and password, but its said “invalid login. Please try again”. I try about 6 times, but is always the same. The moogler acount is the same that “moogspace account”?. My moogspace account status said "156 days until the subscription ends.
Anyone can view, some moogler??
I have the same problem. I can listen to the files that Brian G has posted there, but I cannot look at any of the Moogler stuff. What is the issue?
I also like Brian G’s sounds that he is making with the Moogerfoogers, but I do not see any MF files with Bass or Guitar, just the Voyager! I guess that I need to get off of my lazy bottom and post soemthing!
I tried to enter using firefox and IE. And the same… the log in windows says the same.
Today i can enter to moogler and i only must to log in to moogspace (not to the moogler itself).
Is very cool!
I was also able to now get into the Moogler as well. It is fun, but probably still needs some development. It would not let me hook both my synth and bass into the same input on an effects pedal, but I do share my pedalbaord with both instruments. It also wouldn’t let me use the output of a “black box” to the tap/step input of the MF-105B, as I am using a MIDI clock interface to sync the rate on the MF-105B to the tempo of my drum machine. I will now have to record some samples to post as well!
I tried the Moogler & found if it doesn’t let you make certain connections (or remake connections properly that I had in error), just start anew. I didn’t see a way to delete units so it was kind of a pain. It looks decent though & if they can get the bugs worked out, it’ll be fairly cool.
How do we use the soundfile thing? Do we upload base sounds for each unit & then play them back simultaneously through the routing we make in the tool or what?
I found Mooler very uselfull to share ideas and ways to work. Its need some future development, but is so cool and original.
