to record it to PC all you need is a input to your PC… most desirably some sort of interface, like a m-audio fasttrack pro, or something that works as a interface/pre-amp. Then just run a standard 1/4 inch cable from the audio out to the interface.
If you don’t have a interface but your computer does have a mini headphone jack input for audio in, u can buy a little adapter for a 1/4inch jack to a mini headphone jack. It won’t be the most desirable for sound, but will get u started till u get something better.
A lot of people get confused with the USB, thinking you can use it as audio in.. I’m sure buy now you’ve figured out the USB is just for midi/software updates etc etc.. no audio through USB, but the MIDI through USB can do some crazy stuff!
Depending on what DAW you have and use, theres a ton of cool midi tricks your can do with it. I use Ableton, and some of the arpeggiator effects are sweet… can get some crazy sounds that’d be practically impossible getting manually on the keyboard.
The cool things about samplers is you can record any audio input, crop it and cut it to however short/long a sample you want, and then you can bang out beats and rythms/patterns with them on the pads w your fingers. For drums this is great obviously, cause your not limited to 1 set of sounds, or one kind of sound… you can upload as many kinds of sounds to each pad over and over again. They are great for some cool sound processing too.. meaning you can play a line or pattern from your LP, play it through the sampler, record it, loop it, add effects, record that, loop that, add other effects, record, etc… and layer it and layer it untill you get something really unique, that sometimes does’nt resemble the initial sound at all.
To put it in terms of stuff you’d know, Thom Yorke’s solo album, theoretically could’ve been entirely produced with a sampler. The beats I know for sure are, and a ton of stuff your hearing is just stuff that’s been recorded, cropped, and banged out in a beat w the pads. You can get some really really interesting sounds this way.. and the one’s I mentioned, either a Dr.Boss Sp-303, Sp-404 or Akai MPC500, can be found from anywhere from 200-700 for the latter in the used/new markets.
Actually, http://keyboards-midi.musiciansfriend.com/product/Roland-SP404SX-Portable-Sampler-with-FX?sku=583432 400$ and portable (battery powered if desired) That one’s the big brother to the 303 which I started out with, and learned a TON about producing from.
Depending on wether or not you want to go the software route, there’s a ton of great software out there too… like FXPansions “GURU”… it’s pretty much a super sampler in a software version.
Ton’s of possibilities man if you want to learn how to make/produce/record all your own stuff. Just a heads up, once you start it’s hard to stop. It can turn into a addiction
But a addiction I love
