New LP Stage user here!
Picked up my LP Stage Edition yesterday, #16. It’s everything that I had hoped for :slight_smile:
One thing that sort of caught my eye is the fact that the headphone jack looks slightly malformed, but this has no effect on operation. Anyone else have weird looking headphone jacks?
weird in what way? can you post a pic?
I’ll try and take a picture tonight.
cool, Array!
I’m #666 myself.
didn’t u used to be on a few other synth forums too?
FWIW my headphone jack doesn’t look deformed.
Haha, I didnt know that they even made 666 of them!
I used to be on other forums, but they got stale. I keep to forums related to products I own now.
Also, here is a photo of said headphone jack:
http://img509.imageshack.us/my.php?image=p5090814fc6.jpg
that is how my jack looks on my LP TE.
Cool, thanks for the feedback. It’s no big deal, just a little off center.
Array the same here. I have TE #SE00376 last week, and has the same Jack.
This is my first hardware synth (and the first SE sold in Argentina) and I´m very happy. U can play very easy and sound greeeeeeeat! I used Arturia VST but Little Phatty is really better.
It looks as though the washer isn’t perfectly centered. Other than that, I’m not sure what’s wrong with it. When you plug a line into it, is it straight, or skewed diagonally?
Thanks for the confirmation :slight_smile:
While not my first hardware synth, the Little Phatty is definitely a much welcomed addition.
It’s straight when I plug in a line, a purely cosmetic issue. I just wanted to know if there were others with such jacks.
Just loosen the nut slightly and center the washer, then tighten again.
hmmm yeah yours looks off centered, Array.
Mine isn’t like that, it’s centered.
As for the other forums, yeah some of them have gotten quite off topic and… well, just plain ‘mean’ sometimes. They’re not so cool at times.
yep, that’s clearly all it is. :slight_smile:
WARNING!!
Be very careful with this. The nut is tightened quit snug at the factory. If you try to loosen the nut without holding the jack internally the nut can spin the jack, twist the wires internally and pull the connector off the PCB. Trust me, i’ve done this once or twice.
It may be possible to loosen the nut but if it looks or feels like the jack is spinning as well, stop!
Here’s some advice if you must align the washer. NOTE that opening the LP can void your warrenty! You can remove the screws from the right hand side panel, set the panel and side plate aside, carefully reach in and grab the jack but DO NOT touch the circuit board next to the jack, hold the jack firmly and then loosen the nut. Put everything back like it was when satisfied but be careful to align the side panel screws with all of the holes and put the right screws into the right holes.
Another bit of advice when doing this is to ground yourself using a ground strap or at least make sure you are static free by touching a metal surface before reaching into the LP’s side. ESD (electro static discharge) can damage the internal components. Avoid contact with the PCB’s like the plague.
Obviously the word “Just” wasn’t very well thought out. Thanks, theglyph, for stepping in. I would have hated to give advice that seriously damaged someone’s precious Moog. Hopefully Array hasn’t done anything yet.
Nope! Since its not interfering with the functionality of the synht, I’m just going to leave it as is :smiley:
Thanks to everyone for all of the great help. This forum is awesome!
As Make Magazine says:
hehe
This one is also pretty hilarious!
Just a small confirmation here that the headphone jack of my LP TE also looks like that. I don’t think that I had ever noticed it unless someone had pointed it out to me, so I will let it stay like that…
