Really hoping to hear any sort of timeline on an update to fix the Sub Phatty’s editor from constantly having disconnect issues and also a firmware update to bring it more inline with the Sub37 (this is more wishful thinking) …
with Moog’s reputation for high quality… having a software editor that constantly disconnects is kinda
if you guys need a beta tester (which I guess I already am seeing as the last update I got was a beta that was hoped to fix this issue) … please let me know. I am very well versed in bug tracking , trouble shooting etc.
Sorry for the trouble! If any further issues, let me know.
Oh and if you are using Windows you might try this USB MIDI driver… it supports Sub Phatty, Minitaur and Sub 37 and provides multi-client USB MIDI support, which means that more than one software app can talk to the USB MIDI ports at the same time.
Sorry for this question but how can I proper install the update without troubles.
Directly in the SubPhatty editor (is there a link) or are there other steps to make?
Yes it’s safe. The problem you had before was very specific to that particular beta test; it involved a problem with updating the bootloader. We are not updating the bootloader this time; just the main firmware. (that’s why it’s safe; because there is a bootloader that remains in place to allow for repeated firmware updates)
I cannot account for your results. I too am using Windows 7 64-bit (professional, SP1 if it makes a difference).
I am using the Moog USB MIDI driver with the Sub Phatty and it’s working fine.
I can use the standalone Sub Phatty Editor and it’s working fine; I can use the Sub Phatty Editor plugin and it’s working, no “disconnected” message.
I just realized the plugin editor i’m using is v1.0.3… I’ll test v1.1 again… it’s working for me also. Tested in Cubase v7.5 and Live 9.0.6.
I don’t know if I’m somehow failing to see something obvious that you aren’t doing… I assume you can see and select the Sub Phatty as the MIDI in/out device in the Editor… are you seeing “Hardware disconnected” instead of the firmware version, in the lower left corner of the Preferences page, or are you seeing it somewhere else?
@ Zap_pa:
Yes, the file USB Generic Parent Driver Usbccgp.sys is intalled on my system. Is that good or bad in this case?
@ Amos:
Yes I aso have SP1. But here is a little update on the issue:
after some more testing, I found that the new firmware is working both in standalone and VI after all, at least a LITTLE better than the previous firmware.
the only problem with the firmware I experience now, is that if I automate more than 2 parameters (does not matter which ones), I get weird dropouts, tempo changes and random note playback. In the previous firmware, I also had this problem, but then with more than 1 parameter. I have sent demo files to your developer Salvator regarding this earlier on.
And about the new Moog USB MIDI Driver - I have tried reinstalling this a couple of times now, restarted computer, synth, etc - but it does not work at all. “Moog Sub Phatty” does not show up in the device list in Preferences, and “hardware disconnected” is showing. Both in standalone and VI.
then checked via standalone editor: yes, running v2.0.6.
installed the new USB MIDI driver
then checked via standalone editor: no. “hardware disconnected”.
restarted both computer and Sub Phatty
checked again via standalone editor: nope. hardware disconnected.
checked via VSTi: same. disconnected.
uninstalled the new USB MIDI driver, and restarted moog.
basic usb driver was successfully re-installed.
checked via standalone editor: connected.
checked via VSTi: no. hardware disconnected.
So, the new USB midi driver didn’t do me any good at all,
because now it is even worse than before (the VSTi used to work up until this point).
Same here the new USB driver causes the Sub Phatty to be not recognized.
Removing the new USB driver and everything work fine.
WIn 7 64 SP1 Cubase 7.5 PT 11
Hey, glad to hear I’m not the only one, sort of
Rokatansky, have you also experienced problems with automating more than 2 parameters using the VI-instrument in your DAW?
Same for soundremo, Rokatansky, and any others who are waiting for a better-working Sub Phatty editor.
Here is a newer build of the Windows plugin… this is primarily to see if it appears in the DAW for any users who were not seeing it previously… please let me know.
Denim, I read that your problem with automating more than one parameter at a time seemed to be linked to using a USB3 port, and you didn’t have the same problem on USB2 port, correct?
..but now on USB2 port you are getting “disconnected” message frequently? Hmm… and you’re using firmware v2.0.6?
I’ll write more next week… I may need your help (or someone else’s) to test a debug version of the USB driver, to find out why it’s not working properly on your system.
