Need of some help w/ Ableton setup with Midi driver
I had the editor and sub work fine last night on windows 10,
but I was not using the intended midi driver, I was just using usb & midi together as I do with the Miniataur.
so I have installed the driver, but just need to find out how everyone has it configure with the usb midi driver.
at the minute everything works, only thing is not working is the the automation in ableton live.
hope you cav help me out so I can get stuck in to testing it.
MESA
I’ve got the automation working now.but would be still nice to see how you have it setup :slight_smile:
Hi mesa,
There are a few discussion on the board regarding automation in Ableton. You may also want to check Amos’s tutorial for Minitaur in Ableton, which should be good for the Sub 37 Editor as well.
Hi Gil,
I have my miniataur working fine (well it dose crash ableton a lot when you open the editor) but works well when its not chashing live, and it all SYNC’s correct.
The minitaur’s midi driver doesn’t work, so I was told I had to use the USB & a MIDI cable together until moog have updated the miniataur midi driver.
also my Slim Phatty has to be setup a different way than the other two moogs but that LFO/ARP SYNC’s perfect.
So the setup is different for the 37 but I have it working right now only problem I cant seem to get the SEQ to SYNC right, the LFO SYNC’s, maybe I haven’t set it up right I’ve not had the sub37 a week yet.
As i write this, well, it was working, not any more, just keeps saying the please connect sub 37.
